  • Страница 38 из 38
  • 36
  • 37
  • 38
Tom8820Дата: Вторник, 16.08.2022, 11.08.00 | Сообщение # 556
SintezSi5351_TURBO_v2.9
Hello. Could someone precede the code for SintezSi5351_TURBO_v2.9 to address i2c 0x62. My DDS is on address 0x62. It would be nice if you added the choice of i2c address in the setup menu like for the crystal,PLL....
Best regards, Anton.
Сообщение отредактировал Tom8820 - Вторник, 16.08.2022, 11.15.41
vsteshakДата: Вторник, 16.08.2022, 11.27.37 | Сообщение # 557
Hi. Unfortunately, the author of the firmware, Yuriy ut3mk, has not been in touch since the time when his city was destroyed and captured by the fucking russians. Most likely, no one else will be able to help you.
Сообщение отредактировал vsteshak - Вторник, 16.08.2022, 11.28.32
Tom8820Дата: Вторник, 16.08.2022, 12.30.40 | Сообщение # 558
Thanks for the reply.
Anton
sanndr77777Дата: Воскресенье, 26.03.2023, 18.26.32 | Сообщение # 559
здравствуйте а есть ли прошивки для мега 2650 ?
  • Страница 38 из 38
  • 36
  • 37
  • 38
